84 Delta 88, rear, backing plates
The original part number is 18014440. Goggle that and you'll find new ones, even from GM. Note that despite the fact that some vendors call these LH or RH, the B-body cars used the same backing plates on both sides. The e-brake cable on the RH side actually exits out the rear and loops around to join the cable from the LH side.
https://www.gmpartsonline.net/oem-pa...Y2LWdhcw%3D%3D
Thabks Joe!!!! Have you put the 11' rear brakes on any of your 88 s? Are those backing plates available? I think........ uh oh, there I go again. Gm used same calipers, on both systems 11" and 9,5". That the only difference is the prop valve? I see" large piston" calipers advertised , Can not find specs, of " large piston" calipers If they, really are larger maybe prop valve change not needed That could be done latter if needed. Running 225/ 70/15 tires . I think , the tires would allow more braking, before they would lock, versus stock 205s There goes that " thinkin" again.
