68 Front Line Size
Old September 21st, 2017, 05:28 AM
TheBigBlueBoat's Avatar
68 Front Line Size
What is the line and fitting size for a 1968 Cutlass with drum brakes, front line between the proportioning valve and front right wheel cylinder? I'm assuming it's the standard 3/16" line, but if anyone could confirm that would be great. Thanks.
TheBigBlueBoat is offline
Old September 21st, 2017, 05:36 AM
Front lines are 3/16"
Line from M/C to dist block to rear axle is 1/4"
Lines from rear axle tee fitting to rear wheels are 3/16"
The flare nuts vary in thread size based on location. This was done to prevent improper connections on the assembly line. The repro line vendors all sell these non-standard flare nuts.
joe_padavano is offline
Old September 21st, 2017, 06:53 AM
That's what I thought. Are any of the other fittings oddball sizes, other than the MC fittings?
I suppose I can always try and use the fittings off the old line but it's always nicer to have a line complete to save on fluid loss and bleeding.
Old September 21st, 2017, 06:57 AM
The distribution block/combo valve also used non-standard fittings.
70 ctls
March 17th, 2015 09:18 AM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 68 Front Line Size
