68 disc brakes?
Old July 11th, 2009, 06:14 PM
jensenracing77's Avatar
68 disc brakes?
i think i all ready know but want to make sure. are the disc brakes the same from 68 to 72? i know they were differant in 67 but was not sure about 68.
jensenracing77 is offline
Old July 11th, 2009, 06:36 PM
2blu442's Avatar
They will interchange, but my 1968 has the dual piston calipers and two piece rotors. I don't know if all 1968's had that setup though. John
2blu442 is online now
Old July 11th, 2009, 07:05 PM
Trying to remember member
wmachine's Avatar
Yes, '67 and '68 have the 2-piston calipers. '69 was the first year for the much more common single piston design.
wmachine is offline
Old July 12th, 2009, 10:38 AM
64Rocket's Avatar
I have a complete '68 4 piston set up with the rotors, and I have the single piston set up also, but with no rotors. The question is, has anyone use the '68 rotors with the '69 and up set up?
Gene
64Rocket is offline
Old July 12th, 2009, 02:36 PM
wmachine's Avatar
Gene
Since the 4 piston calipers are son prone to trouble, I don't know why anyone would want to do that. New single piston calipers are not that expensive.
wmachine is offline
Old July 12th, 2009, 04:17 PM
thanks everyone. i have a set of spindles off a 70 and may put them on a 68.
Old July 13th, 2009, 07:25 AM
One last note: The spindles from the 67-68 four piston calipers interchange with those from the 69-72 single piston calipers. Only the bolt-on caliper brackets are different.
joe_padavano is offline
Old July 13th, 2009, 09:07 PM
Yellowstatue's Avatar
Cool Two piece
My '69 Vista had two piece rotors and single piston calipers, I believe it was factory...I don't have any leakage problems since I had stainless sleeves installed in our four piston calipers... Single piston calipers are cheap but four piston are SEXY..
Yellowstatue is offline
72allblackcoupe
April 6th, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
<c. larson>
Cars Wanted
September 23rd, 2006 05:57 PM
Det313
June 22nd, 2006 04:16 PM
Quick Reply: 68 disc brakes?
