'65 Cutlass brake question...
Car originally had 4 wheel drum manual brakes. I pulled off the manual master cylinder and used it to replace a worn out unit on my '65 4 door. Now, I recently acquired a power master cylinder off a '66 that had the same 4 wheel manual brakes. From everything I read, this should be a bolt in set up that will work just fine. I have two questions though.. is it truly a bolt on set up, and there is nothing else that needs changed? Secondly, Where do the vacuum lines run to and is there a place to order these? OR is it just a standard size rubber line that I can get at the hardware store. Motor is non stock, '77 403.
delmontcrusier
May 28th, 2023 07:37 AM
Mocephus
October 1st, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
Del70
August 2nd, 2011 04:40 PM
jon69olds
Wheels and Tires
February 11th, 2011 11:57 AM
