62 Dynamic vacuum tank
Old June 1st, 2017, 12:24 AM
Duneracer's Avatar
I removed the vacuum tank from my 1962 Dynamic 88 as I was inspecting it there was fluid in the tank it smells like some sort of lubricant or oil. Is the tank supposed to be empty or was it supposed to have some sort of lubricant to keep it from rusting from moisture the tank was in great shape with no rust.
Duneracer is offline
Old June 1st, 2017, 04:38 PM
therobski's Avatar
are you referring to the power brake tank? show us some pictures please
therobski is offline
Old June 1st, 2017, 05:35 PM
Duneracer's Avatar
I put the tank back in and I also think there is supposed to be a check valve in case a lose of vacuum.
Old June 1st, 2017, 06:43 PM
therobski's Avatar
Check out this thread I started a while back. https://classicoldsmobile.com/forums...ne-help-2.html
Old June 1st, 2017, 06:46 PM
therobski's Avatar
That most likely is blow by
Old June 1st, 2017, 08:04 PM
Duneracer's Avatar
The liquid is real runny. I would think blow by to be black and thick and smell like fuel and oil what are your thoughts. the car had been setting for 15 years or so any water it would of rusted no rust I put a small scope in the hole to inspect no rust.
joemo
September 21st, 2022 04:47 AM
bob p
March 18th, 2015 09:51 AM
1carsick
October 17th, 2012 09:10 AM
Flye
August 9th, 2012 08:48 AM
Texas442
January 30th, 2012 05:36 PM
Quick Reply: 62 Dynamic vacuum tank
