Relocating 442 sign on front fender
The next job on my 68 442 will be the front fenders.They need some attention to the
lower rear section.I was also planning to move the letters to the right location for a car with the fender stripe.Was planning on cutting out templates for the holes on a waterjet.Bolting it to the existing holes and drill new holes after the template.
To do this I will need the location of the new holes relative to the existing ones.
I know for sure that I have seen this somewere online,but I dont remember where.
Wonder if anybody have seen this and remember where to find this information.
You can buy an assembly manual on ebay for about $25.
It should have the stripe info and dimensions as well as a lot of other useful '68 info.
http://www.ebay.com/itm/OLDSMOBILE-1...f49e71&vxp=mtr
The assembly manual only shows you that's it's in a different location, it doesn't actually give you the measurements. They used templates to pierce the fenders so measurements weren't required
Here are the best pics. No need to measure from your old location to the new. It's all here:
https://classicoldsmobile.com/forums...springs-3.html
The vertical distance is controlled by the posts on the back of the numbers. I have a template somewhere that I can scan into a PDF and you can probably print out and use.
Was just out in the workshop measuring,and these holes are not punched with high accuracy.
The 2 on the left fender is a lot lower than on the right side and did not line up nice with the 44.
Have to make a Cad- drawing to cut a template.If anybody is interested I can make a PDF and post it.
Did you use this thread for your numeral location?
https://classicoldsmobile.com/forums/...springs-3.html
I used the existing holes to make a template,so I only needed the position of two of the holes.
Nufo
February 15th, 2013 10:30 PM
silverriff
November 23rd, 2009 05:56 AM
