Quarter Panel
Quarter Panel
Anyone have any ideas or contacts on where to find an original rear quarter panel for a '68 Cutlass. I have heard it is a nightmare to match up an aftermarket panel, and with no welding or body work experience I want to make it as easy as possible even if it does cost me a little more. Any help would be very much appreciated. Thanks Justin
Hey Justin why dont you try Desert Valley Auto http://www.dvap.com/, I put after market quarters on my 72 and they came out really good.
http://www.tamrazsparts.com/index.ph...29_408_409_511
Try this link. I think you will find exactly what you need.
hey i used goodmark panels but we trimmed all the corners and side marckers off and used the originals left on the car we welded on the side surface instead of cutting at the seam. like at the top of the quarter we game doen the side about a inch or two cut the quarter on the car going around every vital feature true to the ariginal quarter and then the same aon the after market quarter so you have a perfit fit because its your cuts your welding to geather not the manufacturer's look at my pictures in majer projects forum under my resteration.
Actually, they are made/stamped out in Tiawan, as are many auto body parts including some that are shipped in OEM boxes. It's a bit like buying a tool from the Snap on Truck, which is actually Stanley Tools, all of which are manufactured in Tiawan.
Oldssupreme
February 20th, 2013 09:59 AM
