Conv top rear window?
I have a good canvass top on my 69 cutlas. But, a prior owner removed the glass window stating he had problems with it going down. He replaced it with plastic, which now looks pitiful. I picked up a glass one to replace it and can see it was previously glued in place. does anyone have a recommendation on what to use as an adhesive?
thanks,
Steve
thanks,
Steve
Conv rear window
I am looking to use my curtain and just install the glass in it. It would make sense to remove the curtain and adhere the glass on a nice flat surface. But that now sounds like quite a project. The glass I picked up had the remains of some type of adhesive. I am wondering what they would use for glass to fabric? It does have a zipper around 3 sides so I may be able to get it horizontal and adhere the glass? Any idea about the adhesive?
Steve
Steve
The rear glass is bonded to the curtain by the manufacturer. I have never heard of anyone successfully reattaching the glass to the curtain, so if you're able to do it successfully you may be the first one.
I think the zipper curtain was used on some aftermarket replacement tops with a plastic window only as the glass would be too heavy.
A glass rear window curtain is less than $200. You're never going to install a rear glass in a curtain for less than that. Cut your losses and buy the complete rear curtain. I threw two rear convertible glass windows out years ago because no one offered a rear glass installation service
