bottom retaining metal - bottom of front fenders
Old November 14th, 2010, 06:06 AM
lvelocci's Avatar
Hello all,
on my 72 Cutlass 2 dr hardtop - I just pulled the front fender off - wanted to get some surface rust off the inside of the fender - when I pulled it off I realized that the bottom of the fender where there are 2 bolts that attach to the frame just below the door hinges is rusting through.
The original metal looks like it had two holes punched in to allow for the bolt / alignment etc. one of these holes has perferrated through and now looks like a semi circle.
wondering if I should use sheet metal (really small piece) or fiberglass to fix this area up?
Also there appears to be some form of spread gasket like sealer under the fender on the body part of the car wherever there is a seam. Anyone know what this is and what I should replace with? almost looks like a paintable caulking of some type.
Thanks in advance,
Louie
lvelocci is offline
hilbily
Body work
September 9th, 2014 08:54 PM
CrazedCountryRebel
July 7th, 2011 03:02 AM
PalmSpringsOlds
February 11th, 2011 12:50 AM
bjtstarfire
November 29th, 2010 11:10 AM
lvelocci
Body work
November 15th, 2010 11:05 AM
Quick Reply: bottom retaining metal - bottom of front fenders
