1972 Cutlass S Fastback Wheel Arch (Wheel well) Replacement Panels
Old August 12th, 2014, 07:22 PM
CutlassS1972's Avatar
Exclamation 1972 Cutlass S Fastback Wheel Arch (Wheel well) Replacement Panels
My wheels well are rusted to ****. I couldn't find Any replacement panels only for the wheel arch. Does anyone know where I can get a panel from?
CutlassS1972 is offline
Old August 13th, 2014, 07:13 AM
Yeah, buy the larger quarter panel repros and cut out what you need. No one sells just the arch as a patch panel. Alternately, cut what you need from a good parts car.
joe_padavano is offline
Old August 13th, 2014, 10:39 AM
Exclamation
its like 300 for one quarter/ and im in chicago so all the cars are rusted/ but thanks i might be going to other states since i need other parts
Old August 13th, 2014, 10:57 AM
I'd shop around. Auto Body Specialties has them for $209 each. Also, there apparently now there is a patch panel for the area behind the rear wheel openings. Of course, it's a mere $189 vs. $209 for the larger panel. Go figure.
Old August 13th, 2014, 10:59 AM
ok thanks.
Old August 21st, 2014, 09:06 PM
bespokemotoring's Avatar
In my experience if the wheel openings are rusted really bad then you will also need to replace the outer wheel house and patch the rear lower section of the inner wheel house.
bespokemotoring is offline
RandyS
January 17th, 2015 12:36 PM
Green_Goblin
August 19th, 2013 01:06 PM
orthoK
January 10th, 2012 04:26 AM
orthoK
November 27th, 2011 08:05 AM
orthoK
May 16th, 2011 10:10 PM
Quick Reply: 1972 Cutlass S Fastback Wheel Arch (Wheel well) Replacement Panels
