455 Camshafts
Old Feb 15, 2008 | 07:29 PM
Jolly Green's Avatar
455 Camshafts
What camshafts you running and why? I asked Mondello Twister what they suggest and they told me a cam with a duration of 277/285 degrees. That seemed a lil high for a mostly street machine with Test N' Tune at the strip. I read that anything over 250 is generally for a dedicated dragster. What do you guys think?
Old Feb 16, 2008 | 03:52 AM
88 coupe's Avatar
Junior Member
Originally Posted by Jolly Green
........ they told me a cam with a duration of 277/285 degrees ........
Looks like the JM-3-4:
Lifts are: intake = .522" and exhaust = .542"
Advertised duration: Intake = 277° and exhaust = 285°
At .050" valve lift: intake = 230° and exhaust = 238°
Centers of the intake and exhaust lobes are 110° apart.
........ over 250 is generally for........
Your 250° would apply to the .050" number. Which, as you thought, is a bit large for most street applications.
Advertised figures are seldom accurate enough to be useful.
Norm
Old Feb 16, 2008 | 06:21 AM
Bob Gerometta suggests the following cam for a mild street car in his Engine Modification and Tuning Guide.
JM-22-25
266*/274* .512"/.523"
He suggests the following cam for factory modified cars.
402194
308*/308* .474"/.474"
The first cam is available from Mondello and the second is available from Supercars Unlimited. However, I know that Comp Cams makes a copy of the second cam because it was the cam that came stock in the late 60s Hurst Oldsmobiles.
Old Feb 17, 2008 | 07:56 AM
88 coupe's Avatar
Junior Member
Originally Posted by Olds64
Bob Gerometta suggests ........
Based on what? That he thinks the JM-22-25 is best for any 455 that is driven on the street? Not likely.
Because the Mondello tech line recommendation was based on information given by Jolly Green, by default it would be the better choice. That does not mean it would be his best choice.
But, that is not what was asked.
What camshafts you running ........
In my 431 inch, 3900 lb, drive anywhere, street rod.
11.9 seconds, in normal street trim.
With the same cam, but different heads, carb/intake, and rear gears, my 461 was in the mid 12s
........ and why? ........
My choice was the result of a consultation with my builder. For best results, I suggest you use the same approach.
Norm
Old Feb 21, 2008 | 11:47 AM
tonycpe's Avatar
I like your ride Norm.
Old Feb 21, 2008 | 02:31 PM
don71's Avatar
same but different
I am using this cam. My choice was based on the low-buck build I did at the time, this was 1990.
I wanted to keep the engine close to "stock". This included low compression,power brakes so no high stall and highway gears (2:56) and 100% street. It has served me well with no regrets. I was worried at the time, that it is easy to over-cam a street car. I did'nt want bad fuel mileage, it smells, rattles, idles rough and the wife won't drive it syndrome.
Well, things have changed since then and so are my future plans. I am looking closely at the JM 22-25 for ME. YOUR plans may be different.
Just ask your self, where or what rpm range is your car going to be in, most of the time? And build for that. Have fun.
Old Feb 21, 2008 | 09:18 PM
88 coupe's Avatar
Junior Member
Thanks.
Looked like this,
when I bought it.
Street driven, 12 to 1, 468, with this
cam. 11.30s @ 118.
Not my first choice, for a sleeper/stealth application.
Norm
spyke
Aug 18, 2012 09:46 PM
coppercutlass
Jun 18, 2012 11:03 AM
Blownolds
Jan 29, 2012 05:10 PM
72 Olds Project
Aug 30, 2011 03:38 PM
coppertopgmc
Feb 5, 2008 04:27 AM
