Help me ID my 455
Help me ID my 455
Hey everyone,
I have a 1972 Olds Cutlass S that originally had an Olds 350/ TH350, but now has a 455" and a TH400 A/T. It is said that the Engine, Cylinder Heads, and Transmission came out of a '70 Olds. Not sure what car, but the guy I purchased it from was certain about the year. I just wanted to put the casting numbers up to see what you guys could tell me about my drive train...
The Cylinder Heads: "E"
The Engine Block: 396021F
Random Number: CFD403686 (not sure what this is)
I don't have the car in front of me. These numbers were pulled by the current owner who still has this car stored at his house. I asked for the casting numbers, and he texted them to me.
The engine, heads, and transmission have all been rebuilt less than 1k miles ago, documented, and still under warranty. Fuel costs have kept this baby garaged.
So... How is my situation? Good components? I just want to make sure I don't have a pair of smogger heads, and decent compression. Anything you can chip in would be useful.
Thank you for your time.
-Jon
-Jon
Hey everyone,
Pending the VIN derivative, indications are that this is, in fact, a 1970 motor.
Sounds like you have some fine parts. E heads fall into the "above average" category. I had them on my 455 with a comp cam decent intake,carb and headers with 2 1/2 duals. excellent power,was very pleased. I actually went with a cam I thought looked a little big for the street and was pleasantly surprised how well it worked. good luck and try to keep away from mondello. Your checkbook will love you for it.
Yes I can. It was a crane cam from the summit catalog. it had 480 496 lift with 222 230 duration at .050 lift. The cam I was going to use was the 484,512 lift with 216 228 duration but it was backordered when I was building. Ideally I would have liked a but more lift with a tad-VERY little less- duration. As it was this cam pulls like a mother. Big car 71 delta 88 conv,leadfoot owner and I loved every moment.Building a new engine for my 74 delta conv. Going up on the cam,edelbrock heads,roller valvetrain, the works. Should be a lot of fun. Shooting for 530 hp,540 torque. We'll see.
sx455raidercelticfan
November 23rd, 2010 05:45 AM
SKINNY IL
May 14th, 2010 07:12 AM
