Casting numbers and Suffix Codes
Old November 30th, 2011, 10:34 AM
421-6speed's Avatar
I am trying to decode my 394 and, I have looked around the site and can not find any casting or suffix codes or any engine specs. Does this site list those codes? Thanks Dan
421-6speed is offline
Old November 30th, 2011, 12:25 PM
Oldsdruid
rocketraider's Avatar
No, but tell me what year and I can probably find them for you out of the shop books. Remember that 59-62 have big cast iron timing cover/water pump. 63-64 are aluminum timing cover/water pump.
In all cases, E suffix is export low compression and S suffix is Starfire.
rocketraider is offline
Old November 30th, 2011, 05:56 PM
421-6speed's Avatar
Where do I look to find the suffix code. Yes my engine has the round water pump and cast iron timing cover. I did notice that the heads have the 23 cast on the exhaust ports and I did hear that the 23 castings were suppose to be a better casting? Don't know it that is true or not? Block is a CFD casting 582813. There is also a 74 and a 3 so I am assuming one of those #'s is a julian date code. Either Jan 3, 1962 or June 14 or 15 depending on if 62 was or was not a leap year. Sure wish there was more data here.
Old November 30th, 2011, 07:32 PM
Oldsdruid
Ya gotta remember half the folks here cannot identify with 394s. They're used to 65-later engines.
Look on the LH head, between center exhaust port and valve cover. There's a machined pad there. The numbers/letters stamped into it identify the engine.
1962 engine serial numbers start at 300001.
In 62, F prefix indicates a 2-barrel engine, G indicates a 4-barrel.
No suffix letter indicates standard 10.25:1 CR on 2 and 4 barrel engines.
L suffix indicates domestic (US/Canada) low compression 8.75:1 2-barrel engine.
E suffix indicates export low compression 8.3:1 in 2 and 4 barrel versions.
S suffix indicates 10.5:1 CR Starfire engine which also has a more radical cam and valvetrain.
Old November 30th, 2011, 08:00 PM
421-6speed's Avatar
This is exactly what I was looking for. Are you telling me the suffix is on the head and not the block? What do you know about the heads? Is there any truth to the 23 castings? Thanks Dan
musicars
June 10th, 2014 08:49 PM
browntownrodandcustom
January 20th, 2014 03:24 PM
L69
August 26th, 2012 08:52 PM
paige_dart
November 12th, 2007 09:40 AM
omega73
August 17th, 2006 07:24 AM
Quick Reply: Casting numbers and Suffix Codes
