Cost to Rebuild a 455
Old May 23rd, 2010, 09:49 AM
Axeni's Avatar
Hey guys I know this is a loaded questions with a million and one answers.
What I have is a 1970 88/455. It runs good. But it is ugly and needs to be cleaned and painted up. There is no sense to pull a motor to clean up and paint everything may as well rebuild at the same time.I am wondering what I should expect to have it freshened up, pistons, rings,bored. Hopefully being able to reuse crank and connecting rods.
Ideas and suggestions appreciated.
________
Live Sexy Cams
Axeni is offline
Old May 23rd, 2010, 10:27 AM
Warhead's Avatar
Check shops in your area.
Complete rebuild would probably start around $2000, that varies depending on where you live, and depending on wear and tear. The valve job alone, could be from $200-$600 depending on what parts need replaced, and where you live.
Try to find some one local with Oldsmobile experience.
More will chime in with recommendations.
Where you live would help with that.
Put that in your edit sheet.
Jim
Warhead is offline
Old May 23rd, 2010, 10:35 AM
Axeni's Avatar
Excellent thanks much. I live in Southern Ontario. If anyone wants to chime in with someone in the area they worked with :-)
________
Washington Marijuana Dispensaries
Axeni is offline
Old May 23rd, 2010, 02:20 PM
442scotty's Avatar
Canada is gonna cost you a lot more...for a good job with top line parts and balancing...done properly.. Im gonna say 3000-3500 with the shop doing the assembly
442scotty is offline
1973olds98
March 10th, 2018 12:21 PM
cobalt
December 21st, 2013 09:02 PM
INTRUDER
October 3rd, 2012 04:15 PM
442dreamer
August 23rd, 2011 07:28 AM
Nailhead 88
March 4th, 2011 07:21 AM
Quick Reply: Cost to Rebuild a 455
