Hot Air Tubes
Old May 3rd, 2010, 08:32 AM
Gary
Gary's 2 442-S's Avatar
Hot Air Tubes
I am trying to determine if I need to connect the hot air tubes to my carburetor. Hopefully I am using the correct term for this. It is located on the right side of the engine by the carburetor. There is two bolts holding the tubes(@) to the intake manifold. One of tubes is broken off and the other one is missing. I would like to remove the plate and either fix or eliminate the tubing. I do not know if having these tubes connected will affect the performance of the engine. I a little apprehensive on trying to remove the bolts in fear they might break off in the manifold.My engine is a 72 455.Any suggestions would be appreciated
Gary
Gary's 2 442-S is offline
Old May 3rd, 2010, 08:45 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
The tubes help warm the choke spring.
You can block them off if you don't use your choke, or buy another set here.
http://cgi.ebay.com/ebaymotors/Oldsm...item27b0ce1880
J-(Chicago) is offline
Old May 3rd, 2010, 08:58 AM
jeffreyalman's Avatar
choke stove - a complete PITA
luckily I now have an electric choke (edelbrock story here but I had an issue with the gasket leaking, thought it was exhaust manifold @ 1st so strong under load
gasket material lasted a day
finally made a gasket out of a shim made from a brake pad - a slice
been great ever since
jeffreyalman is offline
WTony
December 3rd, 2014 04:16 PM
WTony
September 12th, 2014 06:10 PM
WTony
January 4th, 2014 07:20 AM
Nasty455
May 29th, 2012 05:05 AM
WTony
January 1st, 2011 05:32 PM
Quick Reply: Hot Air Tubes
