1961 394 Fuel Pump Problems
Old Jul 28, 2009 | 05:20 AM
KQQLCAT's Avatar
I am on my second fuel pump and now need another. This is the vacuum pump style. They start leaking oil out of the side where the vent hole is. Is this common? Both pumps still worked fine though. Both were older rebuilds. Is it the materials used in the older pumps?
Pat
Old Jul 28, 2009 | 05:26 AM
I had a 64 98 and swapped to an electric fuel pump because the mechanical fuel pumps I had didn't work. They had both been rebuilt in the past but didn't pump fuel because the rubber diaphragm was deteriorated. You might try Fusicks or Kanter for a new one.
Old Aug 11, 2009 | 09:28 PM
NAS Backyard's Avatar
I'm still running my junkyard pump that was on the engine, it is a AC flat top unit since I have the standard heater. I also found a rebuilt one on ebay last weekend, buy it now for 20.00. I got it for a spare. He had one more left. I found it in the 61 Oldsmobile Buy it now section. It will be a clean core if anything.
Old Aug 22, 2010 | 03:45 PM
Starfire1961's Avatar
Fuel pump vacuum port
Do you guys know where the vacuum line goes from the small vacuum port on the fuel pump? Engine is a 1961 394, thanks
Old Aug 22, 2010 | 10:47 PM
88 coupe's Avatar
Junior Member
Originally Posted by Starfire1961
........ where the vacuum line goes from the small vacuum port on the fuel pump? ........
The one that blows, goes to manifold vacuum.
Norm
Last edited by 88 coupe; Aug 24, 2010 at 01:06 AM. Reason: Corrected a silly error.
Old Aug 23, 2010 | 06:06 AM
Originally Posted by 88 coupe
The one that blows, goes to the intake manifold.
Do you know where exactly on the intake this one should go? thanks
Old Aug 24, 2010 | 01:03 AM
88 coupe's Avatar
Junior Member
No. But the one that sucks cannot go to the wiper motor because '61 used electric, not vacuum power.
After I made the correction, I subjected myself to 10 lashes with a wet noodle.
Norm
Old Aug 24, 2010 | 03:09 PM
dlh61olds's Avatar
Here is a link for fuel pumps and rebuild kits.
Good people to do business
with.http://maritimedragracing.com/then_a...automotive.htm
Dave
Old Aug 31, 2015 | 12:17 PM
Larry/car's Avatar
Vacuum line goes to the deluxe ventilation/ heater controls; through firewall to under dash T fitting, right side of steering column between vent and heat control units.
Old Sep 1, 2015 | 08:21 AM
Tedd Thompson's Avatar
Old thread
Though helpful maybe to someone doubtful the original OP is still in need as this thread is over six years old and 88 Coupe hasn't been with us(passed away) for many of those years..... Tedd
Old Sep 20, 2015 | 05:49 PM
Larry/car's Avatar
Yea I should look at the date. I have been involved with the Corvette Forum and dates are days not years.
chasman414
Jun 25, 2020 07:05 AM
1964starfire
Jan 3, 2011 04:05 PM
sshriber
Mar 22, 2010 06:16 PM
lowdynamo
Jan 10, 2009 03:36 AM
dandl1862
Aug 14, 2006 03:29 PM
