Edelbrock 1813 carb? I don't know alot about ebrocks. This any good?
Does anyone have any experience with the Edelbrock 1813 carb? I ran across one I can get reasonable, guy had it on a small block and says it was too much carb for his setup. It has about 100 miles of use. My motor is pretty much stock rebuilt 70 455, c heads, torker intake and erson tq40 cam. I don't know much about Edelbrock carbs, I've always just run quadrajets on my cars
I had an Edelbrock carb on one of my cars in the past and it was quite streetable right out of the box. It wasn't the Thunder AVS though. I think you will be fine running this on your 455. Just make sure you set your carburetor properly with a vacuum gauge and tach.
How can you make a guess like that without knowing cfm?
Or, one could simply type edelbrock 1813 into Google and get the CFM and other carb specs much more quickly than posting here...
Joe did it ocurr to you or any one who reads what was typed! op,64 then me,then ,64 then old cutlass,then me for why i suggested why post needed a better explantion of the carb is helpful! hint cfm.I guess look up is a google.LOL Then you add gas to it.You three mods need to get togeather for a group hug.
ominayak83
April 18th, 2013 10:55 AM
Bernhard
December 17th, 2012 04:07 PM
dennisspeaks
October 20th, 2011 09:25 PM
19camaro95
December 3rd, 2010 01:50 PM
kingkong8808
February 1st, 2009 05:16 PM
