New 400E and 425 piston
Old December 11th, 2016, 06:12 AM
cutlassefi's Avatar
I am pleased to announce that I have received a verbal commitment on a new forged 400E and 425 piston. Sizes will be 4.100" and 4.155" respectively and have the following specs, although not carved in stone quite yet.
4032 material
.980 pin
1.620 compression distance
8cc D shaped Cup and the most modern ring pack available today, 1.00mm, 1.00mm, 2.00mm all steel ring set.
Price would be in the $600.00 range which would include pistons, pins, clips AND rings. Overall piston weight would be significantly less than all the current pistons available.
Compression would be in the mid 9 range on a 400 with stock heads and the pistons approx. .020 in the hole. A 425 will have upper 9:1 compression.
The goal is one configuration for all applications.
cutlassefi is online now
Old December 11th, 2016, 06:36 AM
lansing's Avatar
425 pistons
Good to hear! I love the 425s and have two of them that I plan to rebuild as soon as the budget allows. Lighter pistons and modern ring packs, yes, that's going on the rebuild parts list!
lansing is offline
Old December 11th, 2016, 06:38 AM
wr1970's Avatar
It is good to have choices. Thanks for your effort on this.
wr1970 is offline
Old December 11th, 2016, 07:30 AM
Very cool, Mark. Given the compression height, I assume these would also work in a 350 block with stock length rods.
Edit: OK, never mind. I just saw the other thread in the small block forum.
joe_padavano is online now
Old December 11th, 2016, 08:19 AM
66-3X2 442's Avatar
The mid 9 CR is ideal for the street. I have a CR of 9.66 in my 66 400 tri carb and it made 475 ft#'s of torque, 411 HP with VP110 & 406 HP with Shell 93 on the pump. I run 36 degrees of advance with no detonation issues. Sounds like good pistons to me.
66-3X2 442 is offline
shamusj
Brakes/Hydraulic Systems
November 17th, 2023 03:47 PM
RandyS
February 6th, 2013 01:24 PM
Kennybill
November 17th, 2012 05:45 AM
L69
August 30th, 2012 09:58 PM
therobski
April 5th, 2011 07:14 PM
Quick Reply: New 400E and 425 piston
