1965 425 oil drain plug
Have you looked in the Help section at your local auto parts store? If they don't have anything you can buy something like this based on the thread size and pitch:
https://www.summitracing.com/parts/sum-g15
The only bad thing is that the new bolt probably won't be a Torx bolt. Then again, I didn't think Torx was used on any classic Oldsmobiles...
Torx fasteners were not used in 1965. That's an eight point drive, Torx has six. The drain plug is really just two 1/2" square drive recesses overlapping by 45 degrees. You can remove it with a 1/2" square drive ratchet and no socket. Threads are pretty common. Just match them up with other drain plugs.
Thanks for replies. I can still engage the plug with a 1/2 drive but just barely. Might try to weld on a hex as suggested, haven't been able to find a new 7/8-20 thread ( I think thats the size) drain plug.
Not so, the thread is something like 7/8-20. I tried to find threaded rod this size to make one but finally found a stock one that I bought one from another CO member. I would have to cut special thread on bar stock to make one.
Ed
Ed
I googled the number and came up with this lead . You will have to call them to make sure they have it and get a price .
http://www.phillipsmusclecarpartsinv...rt-number.html
Dan Wirth
October 18th, 2009 07:27 PM
