what parts should i use?
Old January 10th, 2012, 01:05 PM
1964 olds f85's Avatar
Im rebuilding my 1964 high compression 330 what parts should i use? I mean as far as pistons,cam values and other any suggestion im open!
1964 olds f85 is offline
Old January 10th, 2012, 02:28 PM
Oldsmaniac's Avatar
I assume you mean what parts to re-use.... Depends on what is worn.... if overbore is required you need new pistons. Can reuse cam if good but a good idea to replace lifters. Rockers should be replaced. Valves can be reused if good. You need new bearings. All the big stuff gets reused like intake, water pump plate, oil pan etc. Install new timing chain set.
Oldsmaniac is online now
Old January 10th, 2012, 02:56 PM
Ok thanks for info i dont have cam what should replace with
Old January 10th, 2012, 02:59 PM
Im am going to overbore so which piston should i go with
Old January 10th, 2012, 03:14 PM
Oldsmaniac's Avatar
You can get stock cams and pistons from a few different places. One would be EGGE. You can check them out on the internet.
JpMotorsports
May 15th, 2014 07:08 AM
davesdelta
Body work
October 14th, 2009 12:03 PM
ninob7979
April 7th, 2009 07:19 AM
PmL69
March 22nd, 2009 06:47 AM
327supreme
February 15th, 2009 05:45 PM
Quick Reply: what parts should i use?
