Torque specs and sequence for valve covers 1970 Oldsmobile Cutlass 455
Old April 11th, 2015, 09:48 AM
Don Roberto's Avatar
Can anyone throw some thoughts on the specs and sequence for valve cover bolts on 1970 Olds with 455? Also, I glued the cork gaskets with some 3M weatherstripping adhesive around covers, but no sealant to the head's surface. Is this okay or do I need to add sealant? Thanks.
Don Roberto is offline
Old April 11th, 2015, 10:10 AM
Don't put any sealant on the head side. Torque is 7#s, I just snug and go another 1/4 - 1/2 turn. Start in center and work your way out alternating from bottom to top.
oldcutlass is online now
Old April 11th, 2015, 10:27 AM
Thanks a lot Olds.
Old April 11th, 2015, 10:58 AM
Mr. Johnson
rjohnson442's Avatar
And next week re-tighten them again.
rjohnson442 is offline
Old April 11th, 2015, 11:01 AM
Ok. I see ft/pounds and in/pounds wrenches. Which torque wrench should I pick? Thanks again.
Old April 11th, 2015, 11:37 AM
Oldsragger's Avatar
http://www.442.com/tech/torque.html
Here it stands. 7 ft lbs for valvecovers.
Oldsragger is offline
Old April 11th, 2015, 09:48 PM
Thanks a lot. I successfully spec bolted the covers.
wcourt3010
April 13th, 2015 12:10 PM
ctreutel
June 26th, 2013 04:01 AM
Franks425442
March 9th, 2011 12:08 PM
nukesec1
October 6th, 2009 12:42 PM
stevengerard
September 22nd, 2009 09:07 PM
Quick Reply: Torque specs and sequence for valve covers 1970 Oldsmobile Cutlass 455
