Head bolt torque and sequence?
use this
http://www.442.com/tech/torque.html
and this for sequence
http://www.jegs.com/InstallationInst.../350-60529.pdf
Hey it`s strange .My 66 C.S.M. says 95FT/LB. You n other references quote 80- 90.
Which is correct?
Is it to do with oil on the bolts /or not ?
Is it concerning a 7/16 or 1/2 " bolt ?
Is it not that critical ?
Pretty keen to find out b4 I let the builder loose with my C.S.M.
CHEERS MIKE
Which is correct?
CHEERS MIKE
mike
bolts
torque bolts in a three stage circular pattern, from the center of the head outwards. so like 30, 60, then final...add 5 lbs. if you re-use bolts. 80 lbs. sounds about right.
yeah
i even heard of dudes runnin' a flat bottom chaser tap to clean-out the threads. i've never done that, i did like you said and used compressed air to clean out the holes along with a good blast of Berrymans chemtool. never had a problem with that method and even reused head gaskets. i think olds. motors have good clamping pressure around the cylinders so maybe torque isn't so critical. i know my torgue wrench is like +/- 10% at best, on a good day, so who knows.
Thanks for all the help guys! This site really helps a lot! You can find thousands of websites and info on bowtie motors at any given time, but you really gotta dig deep in google for some reliable olds info!
wcourt3010
April 13th, 2015 12:10 PM
Don Roberto
April 11th, 2015 09:48 PM
