Toro 455 Oil Deflectors
Old March 10th, 2009, 07:07 PM
sklbndt's Avatar
I am using a 69 Toro 455 in my cutlass and will be installing the correct oil pan for my car. Does anyone know if I need to remove the oil deflectors or should I just leave them there? Also, while inspecting the timing set I noticed the oil slinger was cracked and I can't seem to find a supplier. Thanks in advance!!
sklbndt is offline
Old March 11th, 2009, 10:15 AM
I'm not sure the Toro deflectors will fit in the RWD pan. The Toro pan does fit in the A-body chassis, however I don't believe it's as good as some folks think it is. THere is a modest increase in oil volume, however the double hump design traps some oil.
joe_padavano is offline
oldspackrat
February 7th, 2015 10:09 PM
dnmfranco
August 5th, 2014 06:16 PM
vistacruiser1971
December 27th, 2012 07:35 AM
sethj78
December 21st, 2011 03:51 PM
Quick Reply: Toro 455 Oil Deflectors
