Torker vs, Performer
I have both and always thought the performer was best and the one i wanted to use. but reading around here lately i dont know which one i want to use.
My engine is a 455 bored .030, high compression pistons, c-heads, fireball camshaft duration is 314 degrees and .475 lift for both intake and exhaust, hei distributor, hooker long tube headers, 200r4 tranny with a 3000 stall, and 4.10 rear end gears.
it will mostly be a sunday driver, go out and race every once in awhile and occasionally drive it the 30 miles to the bigger city to play.
i have a torker as well, not installed, and from what ive read its best for wide open racing or just given er ****. not the best for low end tork, but olds make so much low end tork im puttin it on my 425 anyway. with a manual you often wind it out any way. giddy up
Do some research, and consider Edelbrock's new Air Gap RPM big block manifold. I believe the operating range will probably better suit your needs (1500-6500). I have a Performer on my big block car, and an RPM on the small block car. Both versions are street cars with the small block having more aggressive characteristics (big inch envy). I have been pleased with both but hood clearance is always a major consideration. Good luck with your project!
I will probably stay with the torker or performer for now. mainly because i already have them. on my next engine i will probably do flat top pistons and aluminum heads then i will do differant intake.
so performer is better for low end torque. torker is better for more torque at higher rpm would that be better for highway?
I'm not an expert but have always heard for daily driving with a stock to mild build the dual plane performer is better. Then for racing or wide open throttle applications the single plane torquer seems to be the best. I know I've pulled torquers off of several boat motors over the years and you can imagine how they were run! John
That's a single pattern cam if I'm not mistaken, anything done to the heads, i.e. crossovers filled etc?
The Performer will drive better and you can run a larger carb with it than you can the Torker. But the Torker will give you more upper end hp. If you do decide to run the Performer cut the center divider down a half inch, helps the upper end.
With those pistons you're at 9.75:1 probably at best.
69CutlassAlex
July 30th, 2013 08:18 AM
rhurstolds74
January 20th, 2013 03:39 PM
