Starter Issues
Solenoid would be first guess. Broken/missing teeth would usually result in that loud screeching "starter mongoose" sound. But it sounds like yours just isn't staying engaged. I would say drop the starter & test it/have it tested.
Have had the same issue and solved it in the past and it was the solenoid. the round copper plate and the stud that hits it both had arc weld bumps and where not making good contact causing the solenoid to not pull in and hold. Filed down the post and flipped the round plate and all was good. Learned this when we used to rebuild things instead of just buying new because money was always the issue when I was young.
Last week I bought (well, leant the money to buy...) a 2000 Cherokee for my boy who's getting his license.
The signals and flashers didn't work right, so I spent a fewl hours yesterday disassembling and reassembling ("several" times ) the signal light / highbeam switch, which was full of green corrosion inside.
Signals work now. Saved him $50
Next I will show him how to solder every wire that goes to the hatch (entire harness over-flexed at the pivot point), and how to bend new brake lines, while explaining to him how much it would cost to pay someone else to do these things (and do them wrong).
[QUOTE=MDchanic;558718]What's this "used to" nonsense?
I still do all my own stuff except engine machine work. Hone brake and master cylinders and use rebuild kits etc as well as several other tasks. Save the money for the "go fast" stuff
Yes - This puppy has Doug's headers on it and the heat has always been an issue. Love seeing melted wires. So it may be the wiring on the starter. If its the drive gear, that won't be to bad. I have a few starters lying around.
Thanks - TP
Thanks - TP
I have had similar problems..in my cases it turned out to be electrical/solenoid related from the heat
Does that front cone come off, or does this happen from the inside? And where would I get the gear, is that avialable separate?
This maybe a bit beyond me. - And it would be something I would have to plan because I couldn't leave the car not running.
Instructions for disassembling the starter are in the Chassis Service Manual.
You unscrew the two long screws and the screw to the solenoid, pull off the nose, separate the thrust collar and the retainer, revealing the snap ring, gently pry the snap ring open enough to slide off the shaft, then slide the drive off.
Installation is the reverse. Once you've got the snap ring in the groove, you snap the thrust collar and the retainer together over it using two pairs of pliers.
It can be done in under five minutes, not including "quality time" on your back removing and installing the starter.
Yes the front cone comes off. Here watch these 2 videos, I know it's a van but a starter is a starter.
http://www.bing.com/videos/search?q=...=0&FORM=NVPFVR
Well - I opted to purchase a rebuilt starter from a local shop. While I will say it is a piece of junk, at least it will keep the car operable while I take apart the original starter.
With the military discount it came out to less then $ 50.00.
Now I can properly fix the old starter without pressure.
TP
TP
