from points to HEI
Old October 24th, 2010, 04:45 PM
1973olds98's Avatar
from points to HEI
I got my rebuilt 455 running,,,I changed over to a HEI system..What plug gap should I run ...And the timing I beleive is set at 10 per manual,,would this change going to a HEI system..
1973olds98 is offline
Old October 24th, 2010, 05:01 PM
ziff396's Avatar
I am not an expert but I am running .044 gap on the plugs, and 38 degrees total timing all in by 3 grand. 18 degrees initial timing. If you have an above stock cam, the timing in the manual will not be the same.
I use a dial back timing light to set mine also.
ziff396 is offline
Old October 24th, 2010, 05:12 PM
1973olds98's Avatar
I am using a stock cam
Old October 29th, 2010, 09:35 PM
Fastbrianman's Avatar
I am running a .045 gap on my plugs with 14 degrees initial timing and a total of 36 all in by 3000 in my 442. I have a 10 degree advance can on the HEI. I set it up for the best performance. A little trial and error can make a big performance difference.
Fastbrianman is offline
joepenoso
June 4th, 2014 01:56 PM
oldsmobilty
August 8th, 2013 12:19 PM
1973olds98
May 25th, 2010 05:44 AM
Wyze
May 14th, 2010 01:29 PM
silverriff
June 2nd, 2008 12:26 PM
Quick Reply: from points to HEI
