points to hei
i think there is an ignition power terminal at the fuse box. you can run it from there to the distributor. the factory never uses a resistor that can be removed that i know of. the only ones i seen were a resistor wire. the entire wire made resistance so it could not be used for the HEI.
joepenoso
June 4th, 2014 01:56 PM
