oldsmobile 455
oldsmobile 455
I have a 1969 Oldsmobile delta 88, it has noisy lifters, and i see lifters are going bad need to replace cam, any advice on which cam i can use please provide part number the car is stock but maybe I can upgrade the cam a bit, any bolt on kits without major modification please help I would like to upgrade the cam without having to modified anything else recommendations. ?? i will also replace the push rods and rocker arms any help on this?? advice?
From experience I wold start with the rockers and bridges. The factory bridges are one piece aluminum and do break from time to time and they can also wear causing slop in the valve train that can't be adjusted out.
You could need a cam and lifters, but I wouldn't start there on a 47 year old engine.
If your set on a cam change, you should get a cam kit, which will have the lifters and the correct springs for the cam. you can change the springs with the heads still on the engine. You will need valve stem seals, a timing chain set, a timing chain gasket set, an intake gasket set.
While your at it, a new intake manifold would be good, and I say, Comp cams roller tip rocker kit. That gives you adjustable rockers.
Gene
Gene
Stick the Toronado 400 hp cam in it. Obviously it is mild enough to cope with accessories and automatic trans. Factory cams have the proper base circle to make sure there is no slop in the valvetrain. If you want more the Engle 18/20 which is like 215/225 on a 112 has a decent low end and good top end power too.
I had that exact cam in my 350, unfortunately it's noisy too. That's what pushed me to educate myself on cams and do my own lobe combinations.
BLACKCADDY
June 2nd, 2015 09:38 AM
rocketraider
January 31st, 2013 06:06 PM
GStage1
April 3rd, 2012 08:44 PM
wmachine
December 30th, 2009 05:55 AM
oldsmohaulic
December 18th, 2009 11:02 AM
