Need a new carb any recomendations??
Old September 20th, 2010, 10:14 AM
65Delta88's Avatar
I have a '65 425 in my '65 Delta 88 its a high compression motor, I have an Edlebrok performer intake manifold, dual exhausts with an "S" manifold, and I currently have a Holley 750cfm 4160 series carb on there (vac secondaries) and it began to leak and flood out. I am wondering if there would be a better carb that I could choose for my setup? Smaller CFM? different series or brand? If it makes any difference I plan on putting a larger cam in and some roller tipped rockers this winter. The car has 3.08 gears in it, stock trans and only winds out to about 4000 rpm.
Suggestion will be much appreciated!!
65Delta88 is offline
Old September 20th, 2010, 12:02 PM
Have you considered rebuilding your Holley?
Olds64 is online now
Old September 20th, 2010, 01:17 PM
philnjean's Avatar
I agree. You might want to consider rebuilding your holley. Don't think you have to much carb for it.
philnjean is offline
Old September 20th, 2010, 01:48 PM
citcapp's Avatar
Sounds to me like the float is sticking. Try running some carb cleaner through it before you get to carried away with buying things
citcapp is offline
Old September 20th, 2010, 02:00 PM
I think we should suggest looking at the OTHER carb selection thread...
joe_padavano is offline
Old September 20th, 2010, 02:42 PM
Warhead's Avatar
buhWAHAHAHA
Now THAT is funny!
I say do what you can afford to do. Even if it means an AFB.
Your car.
Good luck.
Jim
Warhead is offline
63super88
February 19th, 2014 03:04 PM
63super88
February 5th, 2014 10:40 AM
66ninetyeightls
September 23rd, 2009 07:27 PM
PmL69
Paint
July 6th, 2009 05:04 PM
craftsmen22
January 18th, 2009 02:41 PM
Quick Reply: Need a new carb any recomendations??
