Measuring for Main bearing size
Old October 31st, 2010, 01:56 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
I think I have it figured out but looking for a second opinion. I'm rebuilding a 455 and measured the main journals on the crankshaft which came out to:
2.9965, 2.9908, 2.9893, 2.9928 and 2.9907.
All are under the spec limit of 2.9993. I'm assuming I can't use std. bearings cause the bearing clearance would be too great.
Now I'm thinking the crankshaft will have to be turned so I can use the .010 oversize bearings. I'm I thinking correctly? I assume it would need to be turned to the point of achieving the magic bearing clearance. The mains in the block were center bored and are within limits. I have the same problem with the rod journals also. Thanks.
67Olds442X2 is offline
Old October 31st, 2010, 02:28 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
In my opinion, you should shoot for .0025-.0029 on the rods, and between .0030-.0038 on the mains. Closer to the .0038 on # 2 and #4 mains. Those always seem to fry out first.
The rear main I usually go a little bigger, .0040-.0043
Now, a standard crank grinding shop will disagree with this because it is beyond factory spec in their books, but If you are going to be beating on it, you want the extra play.
J-(Chicago) is offline
Old October 31st, 2010, 06:24 PM
Navy P-3 FE (Ret.)
Thanks for the info. I'll have to check 2 other crankshafts I have and see if I can get those numbers, or close to, without having to get one turned. If my forged one doesn't sell, I may use it.
Old November 1st, 2010, 08:27 AM
cutlassefi's Avatar
If your numbers are right that crank is all over the place. You'll need to grind that one .020 under.
I just had a 455 crank/block done for my current customer. The crank was ground to 2.9885, (essentially .010 under) which combined with sizing the main saddles to 3.1875, which is right in the middle of tolerance, gave me a little over .003 clearance on mains 1-4 and about .004 on the rear.
And if it's a street application I wouldn't use the forged crank, imo it's not necessary.
cutlassefi is offline
Old November 1st, 2010, 06:19 PM
Navy P-3 FE (Ret.)
I checked my other two crankshafts and all journals fall within the spec range. I need to double check the saddle measurements again and do a comparison. The first crank will be saved for a later build, better that way since it's drilled for a pilot bearing and my other car is manual. Thanks again for the info.
Another question (dumb one) is what conditions require you to have the crank turned besides a spun bearing or a clearance issue. Do the journals have to be smooth as glass. Some of mine have faint lines running around them. Is there any limits? Thanks.
Old November 1st, 2010, 06:55 PM
cutlassefi's Avatar
If you can't really put a fingernail in them you're probably o.k. Other reasons to grind the crank would be taper along the journal or out of round to mention a couple.
Old November 1st, 2010, 08:17 PM
Navy P-3 FE (Ret.)
Thanks. I'll have to bring it in to get turned, second thought, might as well bring the other one in and get it .020 under. It came with the motor I'm building.
hawks70
October 4th, 2012 07:12 AM
dallasite21
February 26th, 2011 05:05 PM
dster69442
February 17th, 2011 07:20 AM
cbeatty
May 13th, 2010 08:06 AM
macf85
November 14th, 2008 09:10 PM
Quick Reply: Measuring for Main bearing size
