Lifter tick?
Old March 18th, 2009, 07:55 PM
65az's Avatar
Lifter tick?
My 403 that we recently purchased is ticking. Possibly lifter? Can anyone recommend a good mechanic on this website or a reputable shop in Phx?
65az is offline
Old March 21st, 2009, 04:32 PM
Warhead's Avatar
How many miles on the engine?
Lifters don't tick, the rest of the valvetrain makes the racket.
Usually it's the center exhaust rockers that go first, due to oil gumming up inside of the pushrods (due to extreme crossover heat), lack of lubrication accelerating wear.
Rockers wear, Fulcrums wear, pushrods wear-instant ticking.
The newfound slop creates a gap at the valvestem tip.
As long as that IS exactly what you are hearing.
If it is valvetrain noise, are you sure that this is too much for you to fix?
Kelley's automotive could handle this (ONLY if Troy, or Shaun is still there), but it has been awile since I have been there. (602)395-1260
I am in N Phx/ Glendale area.
Where are you located?
Jim in Phx.
Warhead is offline
Old March 21st, 2009, 08:12 PM
65az's Avatar
I am in North Phoenix, off of Happy Valley and 35th Ave... I had another guy look at it and listen to it with his stethascope.. and he says he thinks its only Header Gaskets that are worn out.. so I ordered a new set of them, should be in this week. But if you want to look at it as well, I am always open to another opinion...
65az is offline
Old March 21st, 2009, 09:06 PM
64Rocket's Avatar
If it is a lifter, run a quart of ATF for a 100 miles or so and then drain and put new oil filter and fill some good oil. I like Castrol GTX but what ever you want.
Gene
64Rocket is offline
Old April 23rd, 2009, 11:53 AM
65az's Avatar
UPDATE
Well.. thanks to Warhead.. my ticking is GONE!!!! We just finished replacing all of the Valve Spring Retainers and Keepers.. due to the retainers being too large, and causing the lifter to slightly bump against it which in turn caused the ticking! What a job, and I could not have done this without Jim's help! He is good! Came over, listened to it, diagnosed where exactly it was coming from, and he was right! Thanks again Warhead!!!
65az is offline
Old April 24th, 2009, 01:27 PM
Warhead's Avatar
Thank you for the nice words Chris,
You have some pretty decent mechanical talent, also.
Really enjoyed working with you on the 65, hope we can get together on some more projects.
BTW, the ride was very "motivational".
Jim
Warhead is offline
FlyingV5150
April 6th, 2014 08:41 PM
Koda
December 3rd, 2013 08:50 PM
Mark71
Non-Olds Engines
April 9th, 2013 07:37 PM
Tangovino
July 31st, 2009 03:20 AM
442buyer
March 31st, 2007 06:46 AM
Quick Reply: Lifter tick?
