Lifter choices
Old February 16th, 2010, 01:07 PM
Registered car nut
nonhog's Avatar
Lifter choices
Concerned about brands, having heard issues with overseas lifters.
For this build I'll be going with my Engle 20/22 hyd. cam.
Don't want to spend a fortune but would rather spend more for a quality brand than take chances.
any thoughts are welcome.
nonhog is offline
Old February 16th, 2010, 01:27 PM
My442's Avatar
I have had good luck with Engle lifters.
My442 is offline
Old February 16th, 2010, 02:34 PM
greenslade's Avatar
I have heard the term hydrulic cam many times, what is a hydrulic cam I know what a Hydrulic lifter is I assume a cam that uses hydrulic lifters is refered to as a hydrulic cam, is this right?
greenslade is offline
Old February 16th, 2010, 03:12 PM
cutlassefi's Avatar
A hydraulic cam typically has ramps that are compatible with a hydraulic style lifter. There are normally differences in solid vs. hydraulic ramp profiles. However some are cross compatible, depends on the manufacturer.
As far lifters go, any U.S. made lifter will do the trick. The Chinese stuff that was prevelant some time ago suffered from poor metalurgy and bodies that would distort upon lift causing the lifters to bleed down during operation.
cutlassefi is online now
Old February 21st, 2010, 09:21 AM
dc2x4drvr's Avatar
I think Johnson is making lifters again, they're made in the US.
What Cutlassefi said x2
dc2x4drvr is online now
plee3 64Olds
April 2nd, 2011 06:36 PM
nonhog
December 2nd, 2010 09:03 AM
Aceshigh
February 24th, 2010 07:15 AM
procharged70cutlass
December 21st, 2009 08:03 PM
ImWired
December 19th, 2006 05:40 AM
Quick Reply: Lifter choices
