intake gasket
if the port is not blocked off, it will just burn through the gasket. i know that Mondello has them but i would think you can get them other places. i think i have a set for a big block that i won't use if you can't find them.
If you can find out the crush thickness then use a piece of sheet metal no thicker than that you could then cut a hole in the gasket slightly bigger than the crossover hole for the sheet metal. Use the old turkey tray as a template.
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
