Fresh Rebuild 67 442 PCV Sucking Oil
Old November 1st, 2018, 09:57 AM
  #41
GM MUSCLE's Avatar
Composition Gaskets
The composition gaskets are easily cut out for the heat crossover if you can't find any already open.
Do you still have to use RTV on both sides of the gasket like the turkey pan gasket?
GM MUSCLE is offline
Old November 1st, 2018, 09:58 AM
  #42
66-3X2 442's Avatar
[QUOTE=GM MUSCLE;1134185]If my intake gasket is leaking at the bottom inside, will it give me these symptoms of smoking out the tailpipe and sucking oil out the pcv?[/QUOT
Bottom line,unless there's nothing obvious in the vent system,the only option is to pull the intake. Chances are if the intake gasket is leaking pulling oil in with vacuum,it will be leaking water also. I know it's hard taking an engine apart but what's the option? From what I see,there's nothing wrong with your vent system,so...........
66-3X2 442 is offline
Old November 1st, 2018, 10:01 AM
  #43
GM MUSCLE's Avatar
[QUOTE=66-3X2 442;1134194]
You're right Thank you
Old November 1st, 2018, 10:04 AM
  #44
66-3X2 442's Avatar
It's always good to use sealer on anything that might be an issue. Water passages especially and around where there might be a vacuum issue. It's engine building 101. When you pull the intake and see nothing wrong,change the lifters. I'm telling you there was a huge problem with defective lifters flooding the covers and making the engine pull oil in and smoke.
Old November 1st, 2018, 10:19 AM
  #45
GM MUSCLE's Avatar
Oh yeah, if I am pulling the intake, definitely new lifters after hearing all of the issues they had.. Thanks for your help! I will let you know what happens...
Old November 1st, 2018, 10:29 AM
  #46
66-3X2 442's Avatar
I hate to be the bearer of bad news but as you already know,you gotta problem that's got to be fixed. I had a buddy who had the exact same problem you did and he got a set of good used lifters from me,put them in and it fixed his problem.I do not encourage using used lifters but he didn't want to spend the $$$$ for expensive .921 lifters. At the time,NOS was the only choice but now there are good made in the USA .921 lifters available fro HyLift Johnson. I'm not sure about the price of them now but they were very reasonable last time I checked.
Old November 1st, 2018, 12:11 PM
  #47
A leaking manifold gasket will give symptoms of smoking out the tailpipe, but not the oil sucking in the pcv. You can run the engine for a while with the pcv line capped and see if your issue goes away. There would be no indication of oil under the carb as the oil goes direct into the cylinder and usually this problem makes the engine run like caca because of the vacuum leak. You can also take the breather off the other VC and spray a bunch of breaklean in there, if the idle jumps up the gasket is leaking.
My suggestion was to raise the pcv to create a distance gap for oil to drain back down before being sucked into the valve. I've done it with aftermarket VC's.
oldcutlass is online now
Old November 1st, 2018, 12:37 PM
  #48
66-3X2 442's Avatar
I think he said he put the stock covers back on with the same result.
Old November 1st, 2018, 01:40 PM
  #49
therobski's Avatar
Thanks guys for the tip on this post. Done....
therobski is offline
Old November 1st, 2018, 01:47 PM
  #50
66-3X2 442's Avatar
Ah,I see the old vented oil fill cap.
Old November 1st, 2018, 02:16 PM
  #51
72Cutlass S
gs72's Avatar
[QUOTE][/QUOTEWouldn't that result in your face being in the carburetor?
you can perform this with the air cleaner on and yes it does. It also helps to have long arms. Its not like you have to remain in that position for 10 minutes. If there is a problem you should know in 30 seconds or less.
gs72 is offline
Old October 25th, 2023, 09:31 AM
  #52
matchek's Avatar
HMM I wonder if the drain holes on that head are partially blocked and there's excess oil ?? Thus oil is not draining down the pan sufficiently? I hooked my PVC valve up manifold vacuum in the front of the Q-jet. 67 400E in my 64 F-85. Oil pressure good?
What is your PVC hose connected to? It looks like a rubber cylinder piece. My PVC hose is connected directly to the PVC valve with a little clamp to keep it tight.
matchek is offline
Old October 27th, 2023, 09:42 AM
  #53
sysmg's Avatar
You are responding to a 5 year old thread...
sysmg is offline
beanie
June 28th, 2013 10:45 AM
rmoths
November 22nd, 2012 12:07 PM
BradyB
September 25th, 2012 09:03 AM
fitter bill
January 19th, 2011 04:14 PM
80_cutlass
March 30th, 2010 01:35 PM
Quick Reply: Fresh Rebuild 67 442 PCV Sucking Oil
