find the correct water pump
hey there,
can't believe that its such a PITA to find the correct waterpump for my lady.
i need a standard water pump for a car with A/C with a long snout and an overall length of 6.072" !!! (1970 olds toro GT)
any idea where i can get one of those? or at least you have any part numbers?
need that pump really soon....in germany
rockauto has only one water pump for car with A/C in stock...and thats the one with a short snout
thanks
kay
thanks
kay
Well, sir, the 6.1" water pumps as far as I know all came with the 1.75" inlet nipple, and that combo is far and away the most common Olds V8 water pump on the planet. The typical casting number is 412265, with a large "4" on the RH outlet boss. I have dozens and dozens of used ones, or you can get a nice new one at any parts store. Ask for one from a 1976 Toronado. Pretty sure by 1973, almost all Olds had AC and all of the AC cars used the #4 WP. Beware the stamped impeller pc of crap vs the factory type cast iron impeller.
http://www.ebay.com/itm/Remanufactur...77a8c6&vxp=mtr
I can ship to Europe via USPS but it is very very expensive.
the correct casting # for a 1970 toronado with 6.07" in height would be 404562
see:
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
EDIT: well it looks like they have two different sizes for one casting number 5.95" and 6.07" ..i'm confused
correct me if i'm wrong...but as far as i know..casting # 412265 means 5.95" in height.
see:
see:
There is a 5.1" , a 5.5" and a 6.1" pump.
so this pump will do it, right? its for a 1976 toro
http://www.shopping.com/54301260-pro...LrWUvNw==/info
ok ok...so i wanna order A-1 cardone #58295 via rockauto...
rockauto says this fits for some cars with A/C and on other cars only w/o A/C ...at least the hub height is ok "w/5 15/16" Hub Ht" ..so what means that thing with A/C??
Oldsmobile Toronado 1980-1973 Application Data:
w/A.C. and Standard Pump and w/2 Outlets
Oldsmobile Toronado 1978-1970 Application Data:
w/o A.C. and Standard Pump
http://www.cardone.com/Products/Prod...d=58295&p=rock
can i order that pump??
so i guess you guys are right?...hopefully
jensenracing77
January 27th, 2015 03:41 PM
