Fast Idle Cam 2brrl ...can it be adjusted or replaced
Ok...Low skill level regarding carbs. I have noted in the past the choke plate on my 2brl rochester carb. sticks when cold started. And it requires I hand loosen it. A true pain in the @#&!!! Its clear the Fast idle cam is the issue..it is loose and shaky. Can it be purchased seperately or is there a fix to the issue. Thanks in advance
update...... Thie issue was a small and I mean SMALL spacer washer. I adjusted carb and reset timing and yahoooo the car screams off the line. I found the answer when i found a 64 88 junker in a auto salvage yard and the mouse filled carb was still with engine....I looked closely and bamm there it was a small spacer washer. I have a 300 mile trip thursday and can't wait to let it rip.
