Engine Dyno Results!!!
Old June 27th, 2012, 08:25 PM
  #121
507OLDS's Avatar
You can get Cometics from Summit as well.They come in a variety of bore sizes.
507OLDS is offline
Old June 27th, 2012, 11:09 PM
  #122
ah64pilot's Avatar
I looked at Summit, they don't have all the thicknesses that BTR has...I think he is having them custom made by Cometic. They only show 3 sizes, 4.200 bore (2) and a 4.400 bore - all .040" thick.
ah64pilot is offline
Old June 28th, 2012, 04:23 AM
  #123
380 Racer's Avatar
I have a 4.190 bore and the Cometics are 4.240 X .040. You can go thinner or thicker to suit your needs. All are cutom made. I personally would call Travato to order them.
380 Racer is offline
Old June 28th, 2012, 04:48 AM
  #124
507OLDS's Avatar
Yes,I think he is.
507OLDS is offline
Old June 28th, 2012, 10:44 AM
  #125
ah64pilot's Avatar
I ordered a set of 4.200 bore X .060" Cometics from Bill. I just picked the heads up from the machine shop. We CC'd them after they took off .005" to resurface and they came out to 73 CC's.
Now I have seen everything. Bill seems to think Mondello surfaced the heads before they sent them to me...there's no way .005" should've taken off 4 CC's.
Anyway, with the pistons .005" OUT of the hole, 14 CC valve relief, .060" gasket and 73 CC chambers the compression should stay around 10.65:1. I can live with that...hope it lives now that EVERYTHING Mondello has been replaced.
slam1918
November 19th, 2013 04:56 PM
FinOldsMan
August 14th, 2013 10:45 PM
Joffroi
March 21st, 2012 02:07 PM
Aceshigh
July 30th, 2009 02:48 PM
olds307owner
May 17th, 2007 07:48 PM
Quick Reply: Engine Dyno Results!!!
