Distributor Upgrade Questions
Old August 17th, 2011, 04:58 PM
jo75olds's Avatar
Well my 455 Building Adventure is coming to a close, my bottem end is all assembled and my heads, intake, and carb came today, but it seems that I over looked the distributor.
The 455 Block came with points (eww...), but my '75 350 that this motor will be replaceing has HEI, now here is my question, should I get the Summit HEI "Upgrade" Kit for like $70, or just buy a whole new HEI unit, this motor has been built for street/strip proformance, so I want something that works well around town, and when I take it to the strip, it won't die on me.
Not a fan of cutting corners, or going "cheap" (you get what you pay for, is what my grandfarther always told me) but is it worth it to get a whole new HEI unit.
I don't want one of those ignition boxes in my car just a regular distributor
jo75olds is offline
Old August 17th, 2011, 05:21 PM
Land Yacht Captain
66ninetyeightls's Avatar
The factory HEI unit will work just fine. If it was working when it came off I would clean it up. New cap, rotor and wires and throw it in.
66ninetyeightls is offline
Old August 17th, 2011, 05:48 PM
jo75olds's Avatar
Ok great, it currently works fine, drive her every day, weather permiting
jo75olds is offline
Old August 17th, 2011, 07:39 PM
Why argue with success?
If it ain't broke, don't fix it.
MDchanic is offline
Old August 18th, 2011, 12:02 AM
jo75olds's Avatar
What would I use to clean it up? I took a good look at it, and it's showing it's age (what wouldn't after 36 years), and I would hate to ruin the nice new look of my 455, all painted gold with Aluminum Heads, Intake and Carb... I would buy a new one just because the look would give me nightmares knowing it's under the hood looking like that.
Also, I have been looking around, should I get a new gear for it, I have no idea what shape it's in, as it hasn't been removed since new, but I'm under the assumption that 36 years of running, can't be to good for that gear. (Where would I find a correct style for this ignition)
Thanks in advance, and for all the replies already
Jim
jo75olds is offline
Old August 18th, 2011, 05:28 AM
Land Yacht Captain
You can do a couple of things. Clean it up with degreaser and paint it or have it media blasted and paint or clear coat it. Do that with a new cap and wires and it will look brand new.
Old August 18th, 2011, 06:08 AM
507OLDS's Avatar
The good thing about an HEI is that they either work,or they don't. Nothing in between.If it works fine,I would leave it alone.Just change the cap & rotor.They factory gears are hard material,and they don't seem to wear,so it should be fine.The aftermarket bronze gears,for the roller cams,need to be replaced occasionally due to wear.
507OLDS is offline
Old August 18th, 2011, 07:03 AM
jo75olds's Avatar
Thanks to both of you, I'll prob shoot it with a degreaser, and a scotch brite pad, followed by some paint.
jo75olds is offline
Old August 18th, 2011, 07:07 AM
Lee_A's Avatar
There is a guy I've been using since the late 90's for my distributors, Dave Ray. He takes points distributors, cleans them up, checks/sets all the tolerances, converts them into true magnetic pickup distributors (using actual GM & Ford pieces which can be obtained a NAPA, in an emergency), and will set the curve to match your motor. He will even polish the housing, if you wish.
http://www.davessmallbodyheis.com
Older gentleman, and a one-man show. As such, he is not always as quick with a reply as many of us might like, but he DOES reply and offers a killer product for the price.
Lee Atkinson
Lee_A is offline
.Rocket.Man.
March 10th, 2015 05:18 AM
JpMotorsports
August 28th, 2014 10:02 AM
Mark71
Suspension & Handling
January 25th, 2012 04:32 AM
O's_Car
August 31st, 2009 06:34 PM
glassjaw442
April 12th, 2009 04:48 PM
Quick Reply: Distributor Upgrade Questions
