cam ??? JM-20-22
Old April 7th, 2009, 07:12 PM
0590trab's Avatar
cam ??? JM-20-22
Hi, guys I am needing to know can i run a JM-20-22 with stock valvetrain
1969 olds 455 bored over .040 / C heads / L2323F pistons
jm-20-22
Lift .496 intake
.512 exhaust
dur: 226/230 @ 50
LC 110
the mondello parts book list it in the manual as usable w/ stock rocker
just wanted to know what you guys think...
thanks in advance for any help you give.........trab
0590trab is offline
Old April 8th, 2009, 04:29 AM
My442's Avatar
I have run that cam in 2 different engines.
You will need to rejet the Q-jet and recurve the distributor.
I get 16" of vacuum at idle, so it works with power brakes.
Used the Comp Cams roller tip rockers.
My442 is offline
Old April 8th, 2009, 10:51 AM
BobsW32
Bobsw32's Avatar
I have found that stock rockers are very inconsistant with their ratio.
If you are going to use them I would check them to make certain they all give the same valve lift......Also I hope you are going to install new springs.....Old springs get very tired.......then you will need to check the lifter pre-load as it may very well have changed........and the stock system is non-adjustable so the only way to adjust the rockers is by milling the pedestals or shimming the pedestals depending and which way you should go...
Bobsw32 is offline
Old April 8th, 2009, 07:26 PM
0590trab's Avatar
Thanks Guys, I had a comp cam 292H in this engine, it did not work well ,it mushroomed the bottom of the lifters, rounded off the lobes on the camshaft, bent a few pushrods, so Iwas thinking this JM-20-22 was a little bit smaller, i had heads redone the vavle springs came new w/ comp cam kit,so they are in great shape, so the engine builder said. anyway thanks again for all the help............trab
0590trab is offline
grmchne78
June 25th, 2015 06:23 PM
Oldsmaniac
June 20th, 2014 05:44 AM
Uncle Hulka
March 12th, 2014 03:41 PM
72RocketPower
August 11th, 2005 04:51 AM
Rocketman
November 22nd, 2004 01:59 PM
Quick Reply: cam ??? JM-20-22
