C heads center exhaust
Old December 20th, 2016, 04:35 PM
Tom
Tom's Avatar
Looking for information on blocking the center exhaust ports on C heads.
Tom is offline
Old December 20th, 2016, 05:51 PM
classicmuscle442's Avatar
We blocked the intake center ports with sheet metal, but there are many different ways to do it. Some gasket set can be had already blocked off, sure some with more knowledge will chime in, could also use search feature.
classicmuscle442 is offline
Old December 20th, 2016, 09:14 PM
same but different
don71's Avatar
Do you mean filling in the center divider...or filling the heat risors? Two different things and two different operations. Regardless, the final machining should be done afterwords.
Filling the divider is usually done by brazing or welding to build up the surface and some finish grinding to size.
Filling the risors is pouring molten aluminum or some other alloy in the head and then finishing it.
These picture were taken from this post. Its a good read.
https://classicoldsmobile.com/forums...hniques-3.html
don71 is offline
June 3rd, 2019 11:53 AM
atkinsom
May 29th, 2013 06:39 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
53sled
December 21st, 2009 08:47 PM
Quick Reply: C heads center exhaust
