Bolt pattern on TH425 flexplate 1970 Toronado
Old January 30th, 2014, 12:23 AM
EightballZ's Avatar
hey guys,
i'm about to order a new torque converter.
there are two from TCI that may fit but i don't know about that "small bolt pattern" regarding torque converters for the TH400/425.
can you tell the difference between those TCI converters?
241101 seems to have anti ballooning plate but "small bolt pattern" and is not listed to fit TH425, and 241200 seems to fit TH425 but has no anti-ballooning plate.
TCI told me that 241101 will fit just fine on TH425, but what about that "small bolt pattern"?
maybe you can help?
http://www.tciauto.com/tc/catalogsea...vance&q=241200
http://www.tciauto.com/tc/catalogsea...vance&q=241101
Afaik "anti ballooning plate is good for high-torque engines?
EightballZ is offline
Old January 31st, 2014, 01:30 AM
EightballZ's Avatar
no one? ..would like to order today
Old January 31st, 2014, 01:43 AM
Nop
2-stroke 1-cylinder guy
Nop's Avatar
Moin!
There are 2 flex plate bolt patterns/bolt circles (Lochkreise):
10.75" (small, 27,305cm)
11.5" (large, 29,21cm)
Some flex plates may have both patterns.
Is your engine/tranny already out of the Toro for measuring?
Nop is offline
Old January 31st, 2014, 01:56 AM
EightballZ's Avatar
Danke
yes i knew that already but isnt it possible to tell which year / model came with small or large bolt pattern?
can't measure myself since the engine is off to the machine shop inc. flexplate
Old January 31st, 2014, 02:03 AM
Nop
Nop's Avatar
The ATP Z116 flex plate /w dual pattern is only 30€ @RockAuto:
http://www.rockauto.com/catalog/more...716&cc=1225673
Maybe order one just to be sure?
Nop is offline
EightballZ
September 2nd, 2015 09:51 AM
EightballZ
February 17th, 2013 10:31 PM
Prostreet Lamborghini
November 26th, 2011 12:51 PM
Schober Motorsports
December 10th, 2010 05:29 PM
J-(Chicago)
November 28th, 2007 04:00 PM
Quick Reply: Bolt pattern on TH425 flexplate 1970 Toronado
