Battery
Old November 26th, 2011, 07:28 AM
35mastr's Avatar
Battery
What size battery is needed for a 68 455 in 12 volts? Group#? CCA??
35mastr is offline
Old November 26th, 2011, 09:09 PM
svnt442's Avatar
It depends on what tray is in there. It's either going to be a group 24 or a group 27.
EDIT: I was assuming this was in a 68 Olds, but then again.....
What car are you putting it into?
svnt442 is offline
Old November 27th, 2011, 02:58 PM
35mastr's Avatar
Its going into my Hudson custom. I just wanted to make sure I have the right group size and CCA. Tray size does not really matter as I am going to make one in the trunk. I have a brand new 24F with 582 CCA. Just was not sure that 582 CCA would be enough.
35mastr is offline
Old November 27th, 2011, 06:10 PM
svnt442's Avatar
Not really. That sounds like a VERY cheap battery. I'd get a group 34 with 800cca and 1000ca and be done with it. That will give you all the cranking power you will need and have plenty of reserve if the charging system takes a dump.
http://www.oreillyauto.com/site/c/se...keyword=34extj
svnt442 is offline
59Olds98
December 25th, 2013 08:20 AM
Texas442
March 28th, 2013 07:13 PM
b350m
Aurora
August 3rd, 2011 03:04 PM
w-30dreamin
January 9th, 2010 03:19 PM
bermuda
May 18th, 2006 11:38 AM
Quick Reply: Battery
