Aluminum radiator
Old September 13th, 2009, 10:24 AM
Jhall64's Avatar
Aluminum radiator
Does anyone know who makes a good alum Radiator for a 64 cutlass.
Most companies make them for chevelles, they seem to need alot of fab work.
Jhall64 is offline
Old September 14th, 2009, 08:47 AM
1964f-85's Avatar
Take a drive over to summit, they have a 27 3/8x19" crossflow aluminum radiator that costs (Manual trans $159.95, PN sum-380328 or automatic trans $209.95, PN 381328).
I run one in my 64, its well made and inexpensive.
The only change that needed to be made was that the corners, where the radiator mounts, at the bottom of the support, had to be squared off so the radiator would sit all the way down in.
Depending on what engine you are running you may be able to use the 25 3/4 or the 22" wide version with out any modifications at all.
1964f-85 is offline
Old September 15th, 2009, 10:09 AM
Jhall64's Avatar
Radiator
I was looking at the 25 X 19. Do you think that will be ok with the Big block. I don't want mess with the core support?
Jhall64 is offline
tocicar8825
September 21st, 2021 07:10 AM
1965cutlassragtop
April 3rd, 2011 03:46 PM
cwracer
February 23rd, 2011 07:54 PM
defiant1
May 19th, 2010 04:29 AM
cfair
May 31st, 2009 09:18 AM
Quick Reply: Aluminum radiator
