72 cutlass vacum lines
There are about a dozen original (not reprint) 1972 CSMs on ebay right now, with the cheapest ones at about $20. If you plan to do any work on the car at all, this is the wisest purchase you'll ever make.
Purchasing an original CSM for your vehicle is one of the best investments you can make... Searching the web each time you need information can be time consuming and in many instances questionable as to the accuracy...
Also, there are no electronic originals of these CSMs. Any on-line or CD version is a scan of a paper original. Detail gets lost quickly when you start making copies of copies.
