1969 400 Pistons
Old August 30th, 2010, 04:14 PM
501Paratrooper's Avatar
1969 400 Pistons
Any suggestions on where to get pistons for my 69 400 G block?
I will be using Eagle Connecting rods 6.735 so I will need floating pins.
501Paratrooper is offline
Old August 30th, 2010, 05:06 PM
442Harv's Avatar
Try Mondello, Egge, Or Kanter.
442Harv is offline
Old August 30th, 2010, 05:10 PM
Run to Rund's Avatar
Sonic test the block. If it will bore to 4.00 you can use 327 Chevy pistons after bushing the rods down to.927" If you pick wisely, they will save a couple hundred grams (easier on rods and bearings), give you rings with less tendency to flutteriing (1/8 vs 5/64), and remove the pin offset. Don't deck the block until you see how far they are below deck.
Run to Rund is offline
Old August 31st, 2010, 10:02 AM
Texas Jim
Texas Jim's Avatar
nice advice. the 455 is the same way, you can use different mfg. components, works well, come out cheaper. thank GOD for good machinists.
Texas Jim is offline
Old August 31st, 2010, 03:51 PM
Thanks for info I'll get w/the machinist regarding the sonic test if not Egge it is.
stonecad
February 11th, 2014 05:25 AM
getawaycar
July 13th, 2011 05:13 AM
madwagon56
June 17th, 2011 05:11 AM
66-3X2 442
January 19th, 2011 12:14 PM
69442
August 6th, 2010 05:03 AM
Quick Reply: 1969 400 Pistons
