1967 Cutlass 4 speed throttle linkage
Hey guys I'm in search of the throttle linkage set up for a 4 speed car. Our car had the 400 in it so we don't need the kickdown switch. It now has a 200r4 with a TV cable. If you have one or know where I can get on that would be awesome! Thanks
I can do a 4 barrel auto linkage set up
email me direct at lemoldsnut@aol.com
Larry Moyer
Redmond, Oregon
Larry Moyer
Redmond, Oregon
Well since finding a 4 speed throttle linkage is very hard to find and Im missing the bar that goes from the firewall to the carb plus the bushing in the carb linkage arm im going to make one using 1/4 rod ends like the ones below. I have a universal linkage that we had laying around so Im going to cut one end off and cut threads into and spin on the two rod ends and should work great. I will post some pictures once I get the final product together.
So went and picked up a 1/4-28 die this morning and cut threads into the 1/4 rod Im using for the linkage. Turned out pretty good if I may say myself and not bad for $10 in parts.
hard to find not so much; expensive yes. i have one for 200.00 with the rod
You have a 1967 442 4 speed tranny throttle linkage?
It's not the rod that is different it is the part that bolts to the fire wall. It doesn't have the kickdown switch on it. Just a much cleaner looking setup. And since we are running a transmission that has a TV cable the switch is not needed.
about a year ago someone had on ebay a new part that they were making that would eliminate the switch to make the auto trans linkage the manual trans linkage. I have been trying to locate who it was since and have not been successful anyone hear who was doing that?
He might be trying to get you to run a spark plug out the tail pipe and have it spark on the downshift and flame out the exhaust?
*The*RocketScientist's excessive knowledge and wisdom of all things Oldsmobile sometimes affects his humor.
here is a 66 unit; the 67 looks a little different but fits the same .
http://www.ebay.com/itm/65-66-442-th...tage_Car_Truck
1k442
February 2nd, 2012 10:45 AM
