ABS, Low Trac, Service Light coming on. Need to get state inspection done. Pleas help
Old February 23rd, 2007, 02:02 PM
2001AleroOwner's Avatar
Exclamation ABS, Low Trac, Service Light coming on. Need to get state inspection done. Pleas help
I have a 2001 alero (4 cylinder) with 145K miles on it. ABS, Low Trac, Service Light and sometimes Brake Light are on as soon as my car is in motion(Lights are not lit initially when I turn the engine on. As soon as I change the gear from parking to reverse or drive they all are lit). I took it to Autozone for error code lookup but no codes were reported. I gave it to the dealer for checkup. The dealer initially said it will cost $80 for diagnostic but he called later in the afternoon and said it might require 3 to 4 labor hours to diagnose the problem and will cost me $200. I backed off. I dont know how much more life the car has so don't want to spend too much on it. I live in Texas which requires annual vehicle inspection. I am already due for the inspection. My vehicle will not qualify for inspection as the lights are on. Is there any way to diable the lights and get the state inspection done or any other alternative? I don't want to spend like 1000 bucks on this car and then trash it in a year.
2001AleroOwner is offline
Old February 23rd, 2007, 03:29 PM
Redog's Avatar
Needs a wheel hub, not a big deal
Redog is offline
Old March 5th, 2007, 05:27 AM
davisjd77's Avatar
ABS, Lowtrac light
I'm having the same problem with my 2000 Alero. Is the issue the ABS sensor or a wheel bearing problem? Is there anyway to test the sensor if that is the problem?
davisjd77 is offline
Old March 9th, 2007, 01:18 PM
2Blue 55
American Lead's Avatar
you could take the fuses out of the lights for the inspection. Don't forget to put the fuse back in and you could buy some hubs later on down the road.
American Lead is offline
Old March 11th, 2007, 11:21 AM
bendc003's Avatar
Red face You can get the hub assemblies for less
I have the same problem with my Alero. On other sites I have seen that if water gets into the cable connection for the hub assembly that it can cause a short in the system. In some cases you can clean the connections and use a grease designed for use in electrical connections (I think it is called dielectric grease or something like that) which will keep further corrosion from happening. If this does not work then if you check the resistance rating on the hub assembly with a volt meter you can see which assembly has gone bad and replace it. I have found a replacement hub assembly at 1aauto.com for $64.95 + $12.00 S&H or if you want to be on the safe side and replace both assemblies, it is $124.95 + $16.00 S&H for two assemblies. These may not be ACDelco parts but the cheapest I have found those is at GMPartsDirect.com for $140.40 + S&H each. So, it is either one original or two generic.... same price. Good Luck, Chris
bendc003 is offline
tinascars
May 17th, 2016 07:55 PM
70Post
July 5th, 2009 08:08 PM
catonine
January 18th, 2009 02:46 PM
up488
Brakes/Hydraulic Systems
January 8th, 2007 05:09 PM
155thINF
September 12th, 2006 05:03 AM
Quick Reply: ABS, Low Trac, Service Light coming on. Need to get state inspection done. Pleas help
