Dash 86 442
Old September 25th, 2015, 07:52 AM
Briseno22's Avatar
Dash 86 442 to 87 dash 442
Upgrading my engine I'm my 1986 442 2 was wonder my if the gauge cluster from an 87 442 to would fit and what all things I would need from the 87 ? Cars going to go faster 85 but wanted to keep the gauges Oldsmobile
Briseno22 is offline
Old September 25th, 2015, 04:32 PM
Welcome to the site, I moved your thread here to get you an answer to your question. Post a proper intro in the newbie section with some pics when you get a chance.
oldcutlass is offline
Old September 25th, 2015, 06:00 PM
Olds Fever
CRUZN 66's Avatar
Changing from an 86 - 442 85MPH cluster to an 87 - 442 120MPH cluster should not be an issue from a bolt in stand point.... I do believe the speedometer cables and gears are the same, any GM dealer parts department should be able to verify that for you....
CRUZN 66 is offline
Old November 15th, 2015, 04:27 PM
Anubis's Avatar
Its a direct swap. No changes to your 86' are needed. Hang on to the 87' cluster. They are worth some money due to one year only 120 mph speedo.
Anubis is offline
Big Mikey
May 12th, 2013 05:40 AM
oldspackrat
February 14th, 2013 09:04 PM
Bryan59EC
June 3rd, 2010 10:36 AM
floater98
May 27th, 2010 03:45 AM
DJMatthews
December 12th, 2006 06:36 AM
Quick Reply: Dash 86 442
