So hot in my 68 442 - cooling advice?
Old July 7th, 2015, 02:20 PM
benjamin247's Avatar
Love driving around but can't handle the heat when I'm driving during the day. Any advice on cooling without breaking the bank? I got a quote for about $2500 to have AC installed, but that's a little too high for me. Right now, none of my air vents work.
benjamin247 is offline
Old July 7th, 2015, 03:27 PM
BlackGold's Avatar
'68 has the little winglet windows, right? Use them! They're better than A/C as long as the car is moving.
Fix your vents. What's wrong with them? If they're screwed up, it's also possible that the mixer door is not going all the way to the "cool" position and thereby sending heat into the cabin.
BlackGold is offline
Old July 7th, 2015, 07:11 PM
Lady72nRob71's Avatar
First, fix the vents to work.
Another good idea is to pull the front seats, pull the carpet back and insulate with fatmat or dynaliner to insulate the hot firewall and floorpans from the interior. It made a difference in my '72.
Lady72nRob71 is offline
Old July 7th, 2015, 08:04 PM
Octania's Avatar
bypass the heater core for the summer.
Octania is offline
Old July 7th, 2015, 10:02 PM
What, do you live in Phoenix like I do?
Fun71 is online now
Old July 8th, 2015, 12:28 AM
You don't even have to bypass the heater core -just put a valve in the line and close it.
MDchanic is offline
Old July 8th, 2015, 06:45 AM
Per the OP's other thread, he isn't even sure if this car has A/C or not. It would be helpful to get the answer to that question first, as the answers will vary.
joe_padavano is offline
Old July 8th, 2015, 03:28 PM
According to the previous owner, it had AC at some point but it was removed. He gave me the compressor that it originally came with. I had my mechanic take a look at my car and found where the heat was coming from. There's a palm sized hole in the firewall (driver side) where i'm guessing some AC component was mounted. I'm gonna try to cover that and see if it helps...
Old July 8th, 2015, 05:42 PM
Again, what does "removed" mean? Just the compressor was removed, or EVERYTHING? Is the condenser still in place in front of the radiator? Is the HVAC box still in place under the dash? What about the vacuum controls? The recirculation flapper and actuator in the passenger side kick panel? The fiberglass HVAC box on the passenger side of the firewall? The wiring and vacuum hoses?
By the way, there is no part of the factory A/C that passes through the drivers side of the firewall. There is a grommet in the center of the firewall where the HVAC wire harness and vacuum hoses pass through, however. That hole is not "palm sized", however. In fact, the only hole that size on the driver's side is the one that the main firewall electrical connector mounts in, on the back side of the fuse box.
Old July 9th, 2015, 06:36 AM
There's a palm sized hole in the firewall...
Hmmmmm... Y'know, that just might do it.
How closely did you look at this car before you bought it?
Also, if it is important to you not to be hot in your car, why did you buy a car with the A/C removed?
MDchanic is offline
Redog
March 18th, 2012 09:21 AM
67Olds442X2
June 14th, 2011 06:20 PM
KZ442
May 29th, 2011 04:58 AM
VikingBlue
May 18th, 2010 09:24 PM
Oldsproject
June 21st, 2008 07:03 AM
Quick Reply: So hot in my 68 442 - cooling advice?
