Phosphated hood latch photos
I recently purchased some zinc and manganese phosphate plating chemicals from Palmetto Enterprises.
http://www.palmettoenterprises.net/P...-Welcome-.html
The first part I did was the hood latch on my '70 442.
I was very pleased with the ease of use, and the final results.
So.... I thought that I would share some before and after photos.
Last edited by ROCKET VAPOR; September 30th, 2010 at 11:19 AM. Reason: To restore lost photo link
Last edited by ROCKET VAPOR; September 30th, 2010 at 11:13 AM. Reason: To restore lost photo link
Thanks guys, the parts look alot better in person though.
I put a very heavy coat of Boeshield on these parts and the Boeshield makes the plating appear to be un-uniform in the photos, but it is not.
Very pleased with the product as well. It was very easy to do.
Now I am just trying to spread the good word around about this product
I did this test on the smaller hood latch first. Their zinc phosphate chemical that I used on the hood latch was a exact match to the light gray phosphate on my original hood hinges.
I glass bead blasted the parts first.
I measured out some of the plating chemical and some distilled water into a stainless steel pot. I then placed the pot on a table top electric burner and brought the solution to 180 to 200 deg. I submerged the parts into the solution and about 15 minutes later you get what was in the photo above.
I was shocked how easy it was to do.
I have now restored the photo links though.
Some before and after phosphate plating photos of the hood latch that bolts to the bottom of the hood.
Before
Some signs of original GM gray phosphate plating!
After bead blasting and re-phosphate plating!
Also note the re-plated original circle "ER" marked bolts.
Before
Nice job on the phosphate plating. Did you buy the pint or quart size from Palmetto? Have you used much of the chemicals so far? You purchased both the zinc and manganese, have these parts been treated with the manganese? And finally, once you mix them up are you able to use the solution over or is it a one shot deal? This is exactly what I want to do for a number of parts and I really appreciate you putting these pics up for us. Looks great Lance.
That hood latch was done with some chemical that had been used four times, and it still did a great job plating.
Looks great. A company near me did one for me. I had to remove all the springs because the solution makes them very brittle.
I ended up trading mine for an NOS piece. A total black phosphate latch is not correct. These originally had gold cad plated rivets and latch mechanism.
The first part I did was the hood latch on my '70 442. I was very pleased with the ease of use, and the final results. So.... I thought that I would share some before and after photos.
oldspackrat
September 13th, 2020 05:23 PM
georgiaboy697
July 2nd, 2010 09:23 PM
